Ana içeriğe geç
TomTom XXL 540 Battery Replacement
Neye ihtiyacın var
  1. TomTom XXL 540 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Peel back the sticker on the bottom of the device to reveal the two screws.
  2. TomTom XXL 540 Battery Replacement: adım 2, 1 resimden 1.
    • Unscrew the two T5 Torx screws.
  3. TomTom XXL 540 Battery Replacement: adım 3, 1 resimden 1.
    • Wedge the flat head of the screwdriver into the edge of the device. Gently lift the screen from the cover.
  4. TomTom XXL 540 Battery Replacement: adım 4, 1 resimden 1.
    • Release the yellow ribbon cable.
  5. TomTom XXL 540 Battery Replacement: adım 5, 1 resimden 1.
    • Identify the green motherboard. Unscrew the three screws holding the board in place.
  6. TomTom XXL 540 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the motherboard from the back plate.
  7. TomTom XXL 540 Battery Replacement: adım 7, 1 resimden 1.
    • Unplug the battery from the board.
  8. TomTom XXL 540 Battery Replacement: adım 8, 1 resimden 1.
    • Plug the new battery into the white receptacle on the green motherboard.
  9. TomTom XXL 540 Battery Replacement: adım 9, 1 resimden 1.
    • Transfer the green motherboard back into the back plate and secure it with the 3 screws.
  10. TomTom XXL 540 Battery Replacement: adım 10, 1 resimden 1.
    • Reconnect the yellow ribbon cable and connect the screen and back plate back together.
  11. TomTom XXL 540 Battery Replacement: adım 11, 1 resimden 1.
    • Insert the t-5 screws and tighten to secure.
  12. TomTom XXL 540 Battery Replacement: adım 12, 1 resimden 1.
    • Replace the label to cover the screws.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Mike Sollars
519 İtibar
3 adet Kılavuz yazıldı
Ekip
WRI115, Team 1-1, Ruszkiewicz Spring 2013 WRI115, Team 1-1, Ruszkiewicz Spring 2013 üyesi
WRI115-RUSZKIEWICZ-S13S1G1
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Very similar for the 4FL60 and 6000, except in :
Step 1 the screws are visible without removing any stickers
Step 4 hint: to release the ribbon, each end of the white bar has a self-sprung clip to ease away, try not to break them. And for the models above there is a small cable plug to unclip
Step 5 there are 5 screws holding the motherboard
Step 6 it is necessary to unclip plugs for the battery and speaker leads
and vice versa for reassembly
Jim Shaw - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 4,646
