Ana içeriğe geç
Tomado Blender Carbon Brush Replacement
Neye ihtiyacın var
  1. Tomado Blender Carbon Brush Replacement, Carbon Brush: adım 1, 3 resimden 1. Tomado Blender Carbon Brush Replacement, Carbon Brush: adım 1, 3 resimden 2. Tomado Blender Carbon Brush Replacement, Carbon Brush: adım 1, 3 resimden 3.
    • Remove the base of the blender by removing the 4 screws at underneath..
  2. Tomado Blender Carbon Brush Replacement: adım 2, 2 resimden 1. Tomado Blender Carbon Brush Replacement: adım 2, 2 resimden 2.
    • Detach the base however do not separate it too far as it is still attached!
  3. Tomado Blender Carbon Brush Replacement: adım 3, 3 resimden 1. Tomado Blender Carbon Brush Replacement: adım 3, 3 resimden 2. Tomado Blender Carbon Brush Replacement: adım 3, 3 resimden 3.
    • Detach any cables/wires from the switch panel. They should be attached with an easy to remove pinch clip (just pinch to unclip).
  4. Tomado Blender Carbon Brush Replacement: adım 4, 3 resimden 1. Tomado Blender Carbon Brush Replacement: adım 4, 3 resimden 2. Tomado Blender Carbon Brush Replacement: adım 4, 3 resimden 3.
    • Whilst holding the fan on the inside, unscrew the silicon grip on the top of the blender. This should unscrew with a small amount of force.
  5. Tomado Blender Carbon Brush Replacement: adım 5, 3 resimden 1. Tomado Blender Carbon Brush Replacement: adım 5, 3 resimden 2. Tomado Blender Carbon Brush Replacement: adım 5, 3 resimden 3.
    • Unscrew the 3 screws attaching the motor to the top of the case.
  6. Tomado Blender Carbon Brush Replacement: adım 6, 3 resimden 1. Tomado Blender Carbon Brush Replacement: adım 6, 3 resimden 2. Tomado Blender Carbon Brush Replacement: adım 6, 3 resimden 3.
    • Unscrew the black box holding the safety switch next to where the motor attaches to the case. You can now remove the motor from the case.
  7. Tomado Blender Carbon Brush Replacement: adım 7, 3 resimden 1. Tomado Blender Carbon Brush Replacement: adım 7, 3 resimden 2. Tomado Blender Carbon Brush Replacement: adım 7, 3 resimden 3.
    • Using a soldering iron, heat up the solder attaching the capacitor to the side of the motor. This needs to be repeated on the other side of the motor as there are 2 capacitors (positive and negative).
  8. Tomado Blender Carbon Brush Replacement: adım 8, 3 resimden 1. Tomado Blender Carbon Brush Replacement: adım 8, 3 resimden 2. Tomado Blender Carbon Brush Replacement: adım 8, 3 resimden 3.
    • Using a little pressure, insert a 02 Phillips screw driver into the little black slot next to where you desoldered the capacitor. Use this to hold down the clip that keeps it in place.
  9. Tomado Blender Carbon Brush Replacement: adım 9, 3 resimden 1. Tomado Blender Carbon Brush Replacement: adım 9, 3 resimden 2. Tomado Blender Carbon Brush Replacement: adım 9, 3 resimden 3.
    • Once you have done this be careful when removing the carbon brushes as it is spring loaded.
  10. Tomado Blender Carbon Brush Replacement: adım 10, 3 resimden 1. Tomado Blender Carbon Brush Replacement: adım 10, 3 resimden 2. Tomado Blender Carbon Brush Replacement: adım 10, 3 resimden 3.
    • You can now replace the brushes with new ones and return the clip to its original position. You will need to push the spring back into the slot and this may take some time. Repeat on the other side and your blender should be ready to make smoothie again!
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
where do you buy new brushes?
alex pelchat - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 60
Her zaman: 1,811
