Ana içeriğe geç
Tommy Hilfiger Quartz Watch Band Link Replacement
Neye ihtiyacın var
  1. Tommy Hilfiger Quartz Watch Band Link Replacement, Band Link: adım 1, 1 resimden 1.
    • Place the watch on your wrist and approximate the number of links to be removed.
  2. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 2, 1 resimden 1.
    • Identify the arrows located directly on the links and point them downwards in the south position.
  3. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 3, 3 resimden 1. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 3, 3 resimden 2. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 3, 3 resimden 3.
    • Lay and secure the wristband on the watchband holder.
  4. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 4, 3 resimden 1. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 4, 3 resimden 2. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 4, 3 resimden 3.
    • Align the tip of the pin pusher on the pin.
    • Begin tapping the hammer with force to push the link pin out.
  5. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 5, 2 resimden 1. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 5, 2 resimden 2.
    • Set aside the link pins and links that have been removed from the watch.
  6. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 6, 3 resimden 1. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 6, 3 resimden 2. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 6, 3 resimden 3.
    • In order to add links to the wristband, ensure that the arrows are pointing upwards in the north position.
    • Secure the wristband on the watchband holder.
  7. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 7, 2 resimden 1. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 7, 2 resimden 2.
    • Align the link pins to be added on the holes that connect the desired link to the wristband.
  8. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 8, 3 resimden 1. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 8, 3 resimden 2. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 8, 3 resimden 3.
    • Use the hammer to gently tap the link pins into the holes until the pin is completely resting in position.
  9. Tommy Hilfiger Quartz Watch Band Link Replacement: adım 9, 1 resimden 1.
    • Finally, place the watch on your wrist to determine if the links are secure and the fitment is comfortable.
    • If adjustments need to be made, refer to step 2 for the subtraction of links and step 6 for the addition of links.
Bitiş Çizgisi
Ayush Theyyil
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 52
Son 30 gün: 229
Her zaman: 4,747
