Ana içeriğe geç
Tonneau Trifold Bed Cover Retention Pin Replacement
  1. Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: adım 1, 3 resimden 1. Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: adım 1, 3 resimden 2. Tonneau Trifold Bed Cover Retention Pin Replacement, Retention Pin: adım 1, 3 resimden 3.
    • Locate the two screws on the retaining latch.
    • Use an Allen Wrench to loosen the screws.
    • The screws are tight and may require significant force.
  2. Tonneau Trifold Bed Cover Retention Pin Replacement: adım 2, 2 resimden 1. Tonneau Trifold Bed Cover Retention Pin Replacement: adım 2, 2 resimden 2.
    • Continue loosening the screws until they are both loose enough to remove by hand.
  3. Tonneau Trifold Bed Cover Retention Pin Replacement: adım 3, 3 resimden 1. Tonneau Trifold Bed Cover Retention Pin Replacement: adım 3, 3 resimden 2. Tonneau Trifold Bed Cover Retention Pin Replacement: adım 3, 3 resimden 3.
    • Grab both screws and pull them straight out.
    • Line up the holes on the replacement latch, then insert the new screws.
  4. Tonneau Trifold Bed Cover Retention Pin Replacement: adım 4, 3 resimden 1. Tonneau Trifold Bed Cover Retention Pin Replacement: adım 4, 3 resimden 2. Tonneau Trifold Bed Cover Retention Pin Replacement: adım 4, 3 resimden 3.
    • Hand tighten both of the bolts onto the new latch.
  5. Tonneau Trifold Bed Cover Retention Pin Replacement: adım 5, 2 resimden 1. Tonneau Trifold Bed Cover Retention Pin Replacement: adım 5, 2 resimden 2.
    • Tighten both screws evenly until the latch is held firmly in place.
    • Do not over tighten - you could break the Allen Wrench or strip the screws!
Sonuç
To reassemble your device, follow these instructions in order.
Christopher King
139 İtibar
1 Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 497
