Giriş
I want to show you how to disassembly the body of Toolcraft ST-50D solder station.
Parçalar
Hiçbir parça belirtilmedi.
  1. I think you can disassembly  other models of Toolcraft ST solder stations 50/80/100 analog or digital  the same way.
    • I think you can disassembly other models of Toolcraft ST solder stations 50/80/100 analog or digital the same way.
  2. There are two holes with screws on the bottom side (green circles on the picture) and the 2-nd pair of screws is under the two rubbery "legs" (red circles).
    • There are two holes with screws on the bottom side (green circles on the picture) and the 2-nd pair of screws is under the two rubbery "legs" (red circles).
  3. Android Tamir Setleri
    Yeni bir ekran veya pil, bir tamir kiti kadar yakınında.
    Hemen Alışveriş Yapın
  4. ... by nails or by flat screwdriver and you will see the second pair of holes with screws.
    • ... by nails or by flat screwdriver and you will see the second pair of holes with screws.
  5. ... by Phillips #1 screwdriver and you can open the body of the  solder station.
    • ... by Phillips #1 screwdriver and you can open the body of the solder station.
Sonuç
Martin Kubica
744 Reputation
1 Kılavuz yazıldı
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 13
All Time: 370
