Ana içeriğe geç
Top Shell
Neye ihtiyacın var
    1. Top Shell, Engage Wired Optical Mouse Top and Outer Shell Removal: adım 1, 1 resimden 1.
      • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
      FixBot'a Sor
      Yorum Ekle
    2. Top Shell: adım 2, 1 resimden 1.
      • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
      • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
      FixBot'a Sor
      Yorum Ekle
    3. Top Shell: adım 3, 3 resimden 1. Top Shell: adım 3, 3 resimden 2. Top Shell: adım 3, 3 resimden 3.
      • Grab the top shell of the mouse and lift up to remove.
      FixBot'a Sor
      Yorum Ekle
    4. Top Shell: adım 4, 1 resimden 1.
      • The capacitors on this board can release stored electrical energy if touched.
      • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
      FixBot'a Sor
      Yorum Ekle
    5. Top Shell: adım 5, 2 resimden 1. Top Shell: adım 5, 2 resimden 2.
      • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
      FixBot'a Sor
      Yorum Ekle
    1. Top Shell, Top Shell: adım 6, 1 resimden 1.
      • Remove the 5 mm round head screw holding the middle piece to the top piece.
      • The outermost shell will now separate from the middle structure.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
David
1.316 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G36
3 Üyeler
30 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 2,302
