Ana içeriğe geç
Torque King Electric RTR RC Monster Truck Antenna Replacement
Neye ihtiyacın var
  1. Torque King Electric RTR RC Monster Truck Antenna Replacement, Casing: adım 1, 2 resimden 1. Torque King Electric RTR RC Monster Truck Antenna Replacement, Casing: adım 1, 2 resimden 2.
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Antenna Replacement: adım 2, 1 resimden 1.
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Antenna Replacement, Loosen Screw: adım 3, 1 resimden 1.
    • Loosen the 10mm screw surrounded by the copper using a #2 Phillips head screwdriver.
    • The wire that connects the antenna to the circuitry of the truck might be blocking the screw. Take care when moving the wire out of the way not to pull it from its soldering.
  4. Torque King Electric RTR RC Monster Truck Antenna Replacement, Remove Antenna: adım 4, 1 resimden 1.
    • Carefully slide the antenna out from under the screw and remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Colton Sholtis
257 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-30, Amido Winter 2015 Cal Poly, Team 6-30, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S6G30
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 521
