Ana içeriğe geç
Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement
Neye ihtiyacın var
  1. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Casing: adım 1, 2 resimden 1. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Casing: adım 1, 2 resimden 2.
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: adım 2, 1 resimden 1.
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Removing Screws: adım 3, 1 resimden 1.
    • Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
  4. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Removing the Wheel: adım 4, 1 resimden 1.
    • Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
  5. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Front Wheel Suspension: adım 5, 2 resimden 1. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Front Wheel Suspension: adım 5, 2 resimden 2.
    • Pull the top half of the suspension to unclip it.
  6. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: adım 6, 1 resimden 1.
    • Remove the top clip along with the spring.
  7. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: adım 7, 2 resimden 1. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: adım 7, 2 resimden 2.
    • Pull up the bottom half of the suspension to unclip it.
Sonuç
Maximiliano Cortes
418 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-30, Amido Winter 2015 Cal Poly, Team 6-30, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S6G30
4 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
Hola buenas noches, me pueden hacer el favor de ayudarme a armar de nuevo la parte de la suspensión de la parte delantera, te go todas las piezas pero no recuerdo como van
Vivian giseli Barrero - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 262
