Giriş
This guide requires removing the battery, casing, and rear wheels. Desoldering skills are required for replacing the motor. For reference, a desoldering guide is located here.
Neye ihtiyacın var
From the top view, remove each of the four pins that hold the casing in place.
Beginning at the bottom of the truck, twist the release clip on the casing until the release clip is no longer covering the battery casing.
Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
After removing the rear wheels, use a Phillips #1 screwdriver to remove the two 11m screws indicated.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
My favorite trucks were Chalkboard Chuck and Samson, but I took pictures of several of the trucks and tried repeatedly to snap the perfect picture. {Obviously my perfect pics are a bit fuzzy.}
In addition to the big-honking Monster Trucks we also got to see some daring and dangerous motorcycle stunts!
