Ana içeriğe geç
Toshiba A1304T Camera Replacement
Neye ihtiyacın var
    1. Toshiba A1304T Camera Replacement, Back panel: adım 1, 1 resimden 1.
      • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
      FixBot'a Sor
      Yorum Ekle
    2. Toshiba A1304T Camera Replacement: adım 2, 1 resimden 1.
      • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
      • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
      FixBot'a Sor
      Yorum Ekle
    3. Toshiba A1304T Camera Replacement: adım 3, 2 resimden 1. Toshiba A1304T Camera Replacement: adım 3, 2 resimden 2.
      • If needed, use the flathead screwdriver to gently pry the panel from the phone.
      • Using your fingers, lift the panel from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Toshiba A1304T Camera Replacement, Camera: adım 4, 2 resimden 1. Toshiba A1304T Camera Replacement, Camera: adım 4, 2 resimden 2.
      • Using a small Phillips screwdriver, remove the two black screws from the positions indicated.
      • Gently pull the silver plate from the phone using your fingers.
      FixBot'a Sor
      Yorum Ekle
    2. Toshiba A1304T Camera Replacement: adım 5, 3 resimden 1. Toshiba A1304T Camera Replacement: adım 5, 3 resimden 2. Toshiba A1304T Camera Replacement: adım 5, 3 resimden 3.
      • Using the head of a flathead screwdriver, flip the white segment of the socket that the camera's ribbon-wire runs into so that it is orientated vertically.
      • Gently lift the camera from its cavity and pull it away from the socket using your thumb and forefinger.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Christopher
90 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-6, Maness Spring 2010 Cal Poly, Team 16-6, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G6
4 Üyeler
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 2,486
