Ana içeriğe geç
Toshiba A1304T Logic Board Replacement
Neye ihtiyacın var
  1. Toshiba A1304T Logic Board Replacement, Back panel: adım 1, 1 resimden 1.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. Toshiba A1304T Logic Board Replacement: adım 2, 1 resimden 1.
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Logic Board Replacement: adım 3, 2 resimden 1. Toshiba A1304T Logic Board Replacement: adım 3, 2 resimden 2.
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  4. Toshiba A1304T Logic Board Replacement, Logic Board: adım 4, 3 resimden 1. Toshiba A1304T Logic Board Replacement, Logic Board: adım 4, 3 resimden 2. Toshiba A1304T Logic Board Replacement, Logic Board: adım 4, 3 resimden 3.
    • Use your fingers to gently detach the ribbon wire from the logic board.
  5. Toshiba A1304T Logic Board Replacement: adım 5, 2 resimden 1. Toshiba A1304T Logic Board Replacement: adım 5, 2 resimden 2.
    • Use the flathead screwdriver to pry the logic board and keypad from the device.
  6. Toshiba A1304T Logic Board Replacement: adım 6, 2 resimden 1. Toshiba A1304T Logic Board Replacement: adım 6, 2 resimden 2.
    • Use your thumb to peel the keypad from the device.
Sonuç
Christopher
90 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-6, Maness Spring 2010 Cal Poly, Team 16-6, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G6
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 2,593
