Ana içeriğe geç
Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement
Neye ihtiyacın var
  1. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: adım 2, 2 resimden 1. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: adım 2, 2 resimden 2.
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: adım 3, 1 resimden 1.
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: adım 4, 2 resimden 1. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: adım 4, 2 resimden 2.
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jillian Thomas
209 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G121, Cagle Fall 2017 USF Tampa, Team S1-G121, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S1G121
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 381
