Ana içeriğe geç
Toshiba CB35-C3300 Chromebook 2 Display Replacement
Neye ihtiyacın var
  1. Toshiba CB35-C3300 Chromebook 2 Display Replacement, Display: adım 1, 1 resimden 1.
    • Start by opening your Chromebook and orient the computer as shown.
  2. Toshiba CB35-C3300 Chromebook 2 Display Replacement: adım 2, 1 resimden 1.
    • Using the opening tool, start at one of the two top corners and pull the faceplate away from the display.
    • Use the opening tool to work your way all the way around the frame.
  3. Toshiba CB35-C3300 Chromebook 2 Display Replacement: adım 3, 1 resimden 1.
    • Using a Jimmy, carefully pop the bottom of the faceplate away from the display.
  4. Toshiba CB35-C3300 Chromebook 2 Display Replacement: adım 4, 1 resimden 1.
    • Remove the faceplate by pulling away from the keyboard.
  5. Toshiba CB35-C3300 Chromebook 2 Display Replacement: adım 5, 1 resimden 1.
    • Using an opening tool, start from one of the top corners of the screen and begin to pry it away from the top of the laptop.
    • Make sure that you can keep the foil on the Chromebook.
  6. Toshiba CB35-C3300 Chromebook 2 Display Replacement: adım 6, 1 resimden 1.
    • Using the Jimmy, remove the sticker holding the wire to this display.
  7. Toshiba CB35-C3300 Chromebook 2 Display Replacement: adım 7, 1 resimden 1.
    • Carefully remove the ribbon the display and remove the display from the Chromebook.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 162
