Ana içeriğe geç
Toshiba CB35-C3300 Chromebook 2 Speakers
Neye ihtiyacın var
  1. Toshiba CB35-C3300 Chromebook 2 Speakers, Back Cover: adım 1, 2 resimden 1. Toshiba CB35-C3300 Chromebook 2 Speakers, Back Cover: adım 1, 2 resimden 2.
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 2, 2 resimden 1. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 2, 2 resimden 2.
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 3, 1 resimden 1.
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 4, 2 resimden 1. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 4, 2 resimden 2.
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 Speakers, Battery: adım 5, 2 resimden 1. Toshiba CB35-C3300 Chromebook 2 Speakers, Battery: adım 5, 2 resimden 2.
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 6, 2 resimden 1. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 6, 2 resimden 2.
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 7, 3 resimden 1. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 7, 3 resimden 2. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 7, 3 resimden 3.
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 8, 2 resimden 1. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 8, 2 resimden 2.
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
  9. Toshiba CB35-C3300 Chromebook 2 Speakers, Speakers: adım 9, 2 resimden 1. Toshiba CB35-C3300 Chromebook 2 Speakers, Speakers: adım 9, 2 resimden 2.
    • Remove the 4 Phillip 6.3 mm screws from both the right and left speakers using Phllips 1 screwdriver.
  10. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 10, 1 resimden 1.
    • Gently remove wire from the motherboard by pulling it out of the connector socket.
  11. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 11, 3 resimden 1. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 11, 3 resimden 2. Toshiba CB35-C3300 Chromebook 2 Speakers: adım 11, 3 resimden 3.
    • Remove the right and left speaker by lifting them up.
Sonuç
Mehdi Mohammadi
416 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G121, Cagle Fall 2017 USF Tampa, Team S1-G121, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S1G121
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 204
