Ana içeriğe geç
Toshiba Chromebook 2 Battery Replacement
Neye ihtiyacın var
  1. Toshiba Chromebook 2 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Battery Replacement: adım 2, 1 resimden 1.
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Battery Replacement: adım 3, 2 resimden 1. Toshiba Chromebook 2 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Battery Replacement: adım 4, 2 resimden 1. Toshiba Chromebook 2 Battery Replacement: adım 4, 2 resimden 2.
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Battery Replacement, Battery: adım 6, 2 resimden 1. Toshiba Chromebook 2 Battery Replacement, Battery: adım 6, 2 resimden 2.
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Battery Replacement: adım 7, 2 resimden 1. Toshiba Chromebook 2 Battery Replacement: adım 7, 2 resimden 2.
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Battery Replacement: adım 8, 1 resimden 1.
    • Remove the battery by gently pulling up on the bottom corners.
Sonuç
50 farklı kişi bu kılavuzu tamamladı.
Foster Chaney
762 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Hagerty Fall 2015 IUPUI, Team 1-3, Hagerty Fall 2015 üyesi
IUPUI-HAGERTY-F15S1G3
5 Üyeler
7 adet Kılavuz yazıldı
7 Yorum
does the cb30-b-103 battery also work with the cb30-b-104 series?
henrikahlberg94 - Yanıt
I had four screws holding down battery.
When re-installing cover, don’t get confused. There are two holes under rubber feet on side CLOSEST TO HINGES. These do not accept the two screws - put them on side AWAY FROM HINGES.
Bill Brasier - Yanıt
Good instructions, my chrome is back to normal again .
Alexander Slaven - Yanıt
Many thanks but now there’s no curser! What do I do?
Chris in UK
Chris Tighe - Yanıt
Thank you, easy to follow, works like a dream
steve smith - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 28,782
