Ana içeriğe geç
Toshiba Chromebook 2 Speakers Replacement
Neye ihtiyacın var
  1. Toshiba Chromebook 2 Speakers Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Speakers Replacement: adım 2, 1 resimden 1.
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Speakers Replacement: adım 3, 2 resimden 1. Toshiba Chromebook 2 Speakers Replacement: adım 3, 2 resimden 2.
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Speakers Replacement: adım 4, 2 resimden 1. Toshiba Chromebook 2 Speakers Replacement: adım 4, 2 resimden 2.
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Speakers Replacement: adım 5, 1 resimden 1.
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Speakers Replacement, Battery: adım 6, 2 resimden 1. Toshiba Chromebook 2 Speakers Replacement, Battery: adım 6, 2 resimden 2.
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Speakers Replacement: adım 7, 2 resimden 1. Toshiba Chromebook 2 Speakers Replacement: adım 7, 2 resimden 2.
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Speakers Replacement: adım 8, 1 resimden 1.
    • Remove the battery by gently pulling up on the bottom corners.
  9. Toshiba Chromebook 2 Speakers Replacement, Speakers: adım 9, 1 resimden 1.
    • Remove the 2 3.3 mm screws holding the left and right speakers with the Phillips #0 screwdriver.
  10. Toshiba Chromebook 2 Speakers Replacement: adım 10, 3 resimden 1. Toshiba Chromebook 2 Speakers Replacement: adım 10, 3 resimden 2. Toshiba Chromebook 2 Speakers Replacement: adım 10, 3 resimden 3.
    • Pull the red and white wires out of the socket above the left speaker to disconnect the speakers from the motherboard.
  11. Toshiba Chromebook 2 Speakers Replacement: adım 11, 1 resimden 1.
    • Remove the speakers by lifting upwards.
    • Wiring connecting the left and right speakers may be taped to the top of the battery. Simply remove the tape to remove the speakers.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alec Marnoch
257 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-4, Livingston Fall 2016 Cal Poly, Team 10-4, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G4
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 779
