Ana içeriğe geç
Toshiba Dynabook AX 53D Memory Replacement
Neye ihtiyacın var
  1. Toshiba Dynabook AX 53D Memory Replacement, Battery: adım 1, 1 resimden 1.
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Memory Replacement: adım 2, 1 resimden 1.
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Memory Replacement, Memory: adım 3, 1 resimden 1.
    • Remove the 4.5 mm screw labeled 4 and lift up panel from the vented 2" x "4 memory cover in the middle of the computer.
  4. Toshiba Dynabook AX 53D Memory Replacement: adım 4, 1 resimden 1.
    • Gently pull apart the two metal support clips on either side of the chip to release from the socket. It will spring upwards when it is properly released.
  5. Toshiba Dynabook AX 53D Memory Replacement: adım 5, 1 resimden 1.
    • Gently pull the chip out of the clips.
    • Touching the contacts or the chips on the board could destroy the components.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher
525 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G7, Isaacson Spring 2017 UMass Dartmouth, Team S2-G7, Isaacson Spring 2017 üyesi
UMASSD-ISAACSON-S17S2G7
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 387
