Ana içeriğe geç
Toshiba Dynabook AX 53D Touchpad Replacement
Neye ihtiyacın var
  1. Toshiba Dynabook AX 53D Touchpad Replacement, Battery: adım 1, 1 resimden 1.
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Touchpad Replacement: adım 2, 1 resimden 1.
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Touchpad Replacement, Keyboard: adım 3, 1 resimden 1.
    • Using the #J1 bit, remove the 17 recessed 7.3 mm B6 screws from the underside of laptop and the 3.1 mm #J0 F3 screw inside the battery compartment.
  4. Toshiba Dynabook AX 53D Touchpad Replacement: adım 4, 2 resimden 1. Toshiba Dynabook AX 53D Touchpad Replacement: adım 4, 2 resimden 2.
    • Run the blue plastic opening tool underneath the media bezel and gently pry from the front panel.
  5. Toshiba Dynabook AX 53D Touchpad Replacement: adım 5, 1 resimden 1.
    • Using the #J0 bit, remove the two 3.1 mm screws securing the top of the keyboard.
  6. Toshiba Dynabook AX 53D Touchpad Replacement: adım 6, 2 resimden 1. Toshiba Dynabook AX 53D Touchpad Replacement: adım 6, 2 resimden 2.
    • Pop out the black plastic tab on either side of the ribbon cable. Holding the cable on each side, detach from laptop.
  7. Toshiba Dynabook AX 53D Touchpad Replacement, Touchpad: adım 7, 2 resimden 1. Toshiba Dynabook AX 53D Touchpad Replacement, Touchpad: adım 7, 2 resimden 2.
    • Detach the white plastic end of the braided LCD cable.
  8. Toshiba Dynabook AX 53D Touchpad Replacement: adım 8, 2 resimden 1. Toshiba Dynabook AX 53D Touchpad Replacement: adım 8, 2 resimden 2.
    • Using the flat metal spatula tool, detach the thin white and black wires from their pop connectors.
  9. Toshiba Dynabook AX 53D Touchpad Replacement: adım 9, 3 resimden 1. Toshiba Dynabook AX 53D Touchpad Replacement: adım 9, 3 resimden 2. Toshiba Dynabook AX 53D Touchpad Replacement: adım 9, 3 resimden 3.
    • Using the #J1 Phillips Screwdriver, remove the four 7.6 mm screws that secure the monitor to rest of laptop.
    • The monitor can now be gently removed by lifting upwards.
  10. Toshiba Dynabook AX 53D Touchpad Replacement: adım 10, 1 resimden 1.
    • Run the plastic opening tool along the crease between the top touchpad bezel and bottom section of laptop.
  11. Toshiba Dynabook AX 53D Touchpad Replacement: adım 11, 2 resimden 1. Toshiba Dynabook AX 53D Touchpad Replacement: adım 11, 2 resimden 2.
    • Gently detach the touchpad bezel.
    • The ribbon cable may break if removed roughly.
    • Gently remove the white ribbon cable.
  12. Toshiba Dynabook AX 53D Touchpad Replacement: adım 12, 1 resimden 1.
    • Remove the six 3.7 mm #J1 screws holding the touchpad in place.
  13. Toshiba Dynabook AX 53D Touchpad Replacement: adım 13, 1 resimden 1.
    • Gently pull the ribbon cable to disconnect it from the touchpad.
  14. Toshiba Dynabook AX 53D Touchpad Replacement: adım 14, 1 resimden 1.
    • Carefully pry up the touchpad with a plastic opening tool.
  15. Toshiba Dynabook AX 53D Touchpad Replacement: adım 15, 1 resimden 1.
    • The touchpad has been removed.
Sonuç
Christopher
510 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G7, Isaacson Spring 2017 UMass Dartmouth, Team S2-G7, Isaacson Spring 2017 üyesi
UMASSD-ISAACSON-S17S2G7
3 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 376
