Ana içeriğe geç
Toshiba Dynabook T552-58G Battery Replacement
  1. Toshiba Dynabook T552-58G Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the computer so that the back panel is facing you.
  2. Toshiba Dynabook T552-58G Battery Replacement: adım 2, 2 resimden 1. Toshiba Dynabook T552-58G Battery Replacement: adım 2, 2 resimden 2.
    • Push the right battery cover lock (labeled as number 1) to the right.
    • It should now be on the unlock symbol.
  3. Toshiba Dynabook T552-58G Battery Replacement: adım 3, 1 resimden 1.
    • Push and hold the left battery cover lock (labeled as number 2) to the left.
    • It should now be on the number 2.
  4. Toshiba Dynabook T552-58G Battery Replacement: adım 4, 2 resimden 1. Toshiba Dynabook T552-58G Battery Replacement: adım 4, 2 resimden 2.
    • While holding the left battery cover lock, pull up on the indent found in the center of the battery pack.
    • Lift up on the battery pack to remove it from computer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 716
