Ana içeriğe geç
Toshiba Dynabook T552-58G Fan Replacement
Neye ihtiyacın var
  1. Toshiba Dynabook T552-58G Fan Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn the Toshiba Dynabook T552-58G so that the back panel is facing you.
  2. Toshiba Dynabook T552-58G Fan Replacement: adım 2, 2 resimden 1. Toshiba Dynabook T552-58G Fan Replacement: adım 2, 2 resimden 2.
    • Remove the 10 screws located on the back panel of the Toshiba Dynabook T552-58G using a PH 0 screwdriver.
    • Each screw will be 5.3 mm long.
  3. Toshiba Dynabook T552-58G Fan Replacement: adım 3, 3 resimden 1. Toshiba Dynabook T552-58G Fan Replacement: adım 3, 3 resimden 2. Toshiba Dynabook T552-58G Fan Replacement: adım 3, 3 resimden 3.
    • Remove the black screw using the J0 screwdriver. This is located by the top right foot of the device.
    • This will allow removal of the hard drive cover.
    • This screw will not come out of the hard drive cover.
  4. Toshiba Dynabook T552-58G Fan Replacement: adım 4, 1 resimden 1.
    • Remove the single screw located below the hard drive using the J0 screwdriver. This screw is 5.3 mm long.
  5. Toshiba Dynabook T552-58G Fan Replacement: adım 5, 3 resimden 1. Toshiba Dynabook T552-58G Fan Replacement: adım 5, 3 resimden 2. Toshiba Dynabook T552-58G Fan Replacement: adım 5, 3 resimden 3.
    • Remove two screws located diagonally from the bottom-left screw of the hard drive using a J0 screwdriver. The screw closest to the hard drive is 5.2 mm long and the screw farther away is 4.2 mm long.
    • Remove the screw located diagonally from the top right screw of the hard drive using a J0 screwdriver. This screw is 5.2 mm long.
  6. Toshiba Dynabook T552-58G Fan Replacement: adım 6, 3 resimden 1. Toshiba Dynabook T552-58G Fan Replacement: adım 6, 3 resimden 2. Toshiba Dynabook T552-58G Fan Replacement: adım 6, 3 resimden 3.
    • Slowly lift the back panel away from the computer.
    • There should be some resistance.
    • Once lifted, carefully remove the back panel.
  7. Toshiba Dynabook T552-58G Fan Replacement, Fan: adım 7, 1 resimden 1.
    • After removing the back panel, locate the fan in the bottom right corner.
    • Make sure computer is turned off and unplugged.
  8. Toshiba Dynabook T552-58G Fan Replacement: adım 8, 1 resimden 1.
    • Remove the two screws located on the top left and bottom right of the fan. You should use a PH 0 screwdriver.
    • Both screws are 2.7 mm long.
  9. Toshiba Dynabook T552-58G Fan Replacement: adım 9, 2 resimden 1. Toshiba Dynabook T552-58G Fan Replacement: adım 9, 2 resimden 2.
    • Gently lift the fan away from the base. There should be three wires that are connected to the base of the computer through a port.
  10. Toshiba Dynabook T552-58G Fan Replacement: adım 10, 1 resimden 1.
    • With your fingers, carefully pinch the white connector and pull up.
    • There will be some resistance.
  11. Toshiba Dynabook T552-58G Fan Replacement: adım 11, 1 resimden 1.
    • Remove the faulty fan.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 665
