Giriş
If your computer is crashing, or your computer’s hard drive has been damaged, use this guide to replace the hard drive. By following this guide, you will be able to replace the hard drive with little difficulty.
Neye ihtiyacın var
Remove two screws located diagonally from the bottom-left screw of the hard drive using a J0 screwdriver. The screw closest to the hard drive is 5.2 mm long and the screw farther away is 4.2 mm long.
Remove the screw located diagonally from the top right screw of the hard drive using a J0 screwdriver. This screw is 5.2 mm long.
The hard drive is located in the under the L-shaped panel on the back of the computer.
Bir Yorum
Está em inglês deveria ter como traduzir aqui dentro da plataforma
