Ana içeriğe geç
Toshiba Dynabook T552-58G Space Bar Replacement
  1. Toshiba Dynabook T552-58G Space Bar Replacement, Space Bar: adım 1, 1 resimden 1.
    • The space bar is located on the bottom of the keyboard.
  2. Toshiba Dynabook T552-58G Space Bar Replacement: adım 2, 2 resimden 1. Toshiba Dynabook T552-58G Space Bar Replacement: adım 2, 2 resimden 2.
    • Gently pry the broken space bar up with from the back with your finger.
  3. Toshiba Dynabook T552-58G Space Bar Replacement: adım 3, 1 resimden 1.
    • You should now see the key retainer.
    • Do not remove anything else because this is crucial for replacing the key.
  4. Toshiba Dynabook T552-58G Space Bar Replacement: adım 4, 3 resimden 1. Toshiba Dynabook T552-58G Space Bar Replacement: adım 4, 3 resimden 2. Toshiba Dynabook T552-58G Space Bar Replacement: adım 4, 3 resimden 3.
    • Gently lift up the bottom metal prongs.
    • Insert the two ends of the prong into the small metal loops located at the top of the key pad.
    • Gently press the key down until you hear a click.
Bitiş Çizgisi
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 473
