Ana içeriğe geç
Toshiba Encore 2 WT10-A Battery Replacement
Neye ihtiyacın var
  1. Toshiba Encore 2 WT10-A Battery Replacement, Battery: adım 1, 3 resimden 1. Toshiba Encore 2 WT10-A Battery Replacement, Battery: adım 1, 3 resimden 2. Toshiba Encore 2 WT10-A Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Start by holding your Toshiba tablet faced up.
    • Flip the tablet from left to right so that you are able to see the back of the tablet.
    • Hold tablet and be ready to continue onto the next steps.
  2. Toshiba Encore 2 WT10-A Battery Replacement: adım 2, 3 resimden 1. Toshiba Encore 2 WT10-A Battery Replacement: adım 2, 3 resimden 2. Toshiba Encore 2 WT10-A Battery Replacement: adım 2, 3 resimden 3.
    • Insert a plastic opening tool in the back case of the tablet to free the clips.
    • Begin to pull the tool up slightly and work your way around the tablet to free all the clips.
    • Using a metal opening tool as shown in the photos has the potential to damage your device.
  3. Toshiba Encore 2 WT10-A Battery Replacement: adım 3, 3 resimden 1. Toshiba Encore 2 WT10-A Battery Replacement: adım 3, 3 resimden 2. Toshiba Encore 2 WT10-A Battery Replacement: adım 3, 3 resimden 3.
    • Hold back lid with your right hand and keep lifting to remove the back lid.
    • Pull the back lid from right to left and top to bottom.
    • Once you disconnect the back lid, place lid aside.
  4. Toshiba Encore 2 WT10-A Battery Replacement: adım 4, 2 resimden 1. Toshiba Encore 2 WT10-A Battery Replacement: adım 4, 2 resimden 2.
    • Use plastic spudger to remove the attached battery wires by pushing the plastic wire holder from right to left on top and bottom part of plastic holder.
  5. Toshiba Encore 2 WT10-A Battery Replacement: adım 5, 3 resimden 1. Toshiba Encore 2 WT10-A Battery Replacement: adım 5, 3 resimden 2. Toshiba Encore 2 WT10-A Battery Replacement: adım 5, 3 resimden 3.
    • Start by using your left hand on the top left corner on the battery.
    • Then, begin to lift and work your way around the battery.
  6. Toshiba Encore 2 WT10-A Battery Replacement: adım 6, 2 resimden 1. Toshiba Encore 2 WT10-A Battery Replacement: adım 6, 2 resimden 2.
    • Remove the battery from the compartment.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 1,813
