Ana içeriğe geç
Toshiba Encore Mini Battery Replacement
Neye ihtiyacın var
    1. Toshiba Encore Mini Battery Replacement, Battery: adım 1, 2 resimden 1. Toshiba Encore Mini Battery Replacement, Battery: adım 1, 2 resimden 2.
      • To replace the battery, the rear cover must first be removed.
      • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
      • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
      FixBot'a Sor
      Yorum Ekle
    2. Toshiba Encore Mini Battery Replacement: adım 2, 1 resimden 1.
      • Remove the rear cover and set it aside.
      FixBot'a Sor
      Yorum Ekle
    3. Toshiba Encore Mini Battery Replacement: adım 3, 1 resimden 1.
      • Carefully remove the electrical tape that holds the battery in place.
      FixBot'a Sor
      Yorum Ekle
    4. Toshiba Encore Mini Battery Replacement: adım 4, 2 resimden 1. Toshiba Encore Mini Battery Replacement: adım 4, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
      FixBot'a Sor
      Yorum Ekle
    5. Toshiba Encore Mini Battery Replacement: adım 5, 1 resimden 1.
      • Gently lift the battery out of the device.
      • Be careful not to pull on the connecting wires.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Erica Jouglard
263 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-3, Liner SU 2015 UW Tacoma, Team 1-3, Liner SU 2015 üyesi
UWT-LINER-SU15S1G3
4 Üyeler
15 adet Kılavuz yazıldı
2Kılavuz Yorumları
Be sure to remove any SD cards you have first.
ecw0647 - Yanıt Paylaş
But where do i buy the battery?
sissyhana - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 4,473
