Ana içeriğe geç
Toshiba Encore Mini Speakers Replacement
Neye ihtiyacın var
  1. Toshiba Encore Mini Speakers Replacement, Battery: adım 1, 2 resimden 1. Toshiba Encore Mini Speakers Replacement, Battery: adım 1, 2 resimden 2.
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Speakers Replacement: adım 2, 1 resimden 1.
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Speakers Replacement: adım 3, 1 resimden 1.
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Speakers Replacement: adım 4, 2 resimden 1. Toshiba Encore Mini Speakers Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Speakers Replacement: adım 5, 1 resimden 1.
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
  6. Toshiba Encore Mini Speakers Replacement, Speakers: adım 6, 1 resimden 1.
    • Use the spudger to pull the speaker wire plug from its socket.
  7. Toshiba Encore Mini Speakers Replacement: adım 7, 1 resimden 1.
    • Carefully use the metal spudger to remove the speaker from the frame of the phone.
    • The speaker is attached with some double-sided adhesive and may be difficult to remove.
Sonuç
Khaled Alsaghayer
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S5-G5, Wilson Spring 2017 IUPUI, Team S5-G5, Wilson Spring 2017 üyesi
IUPUI-WILSON-S17S5G5
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 10
Her zaman: 158
