Giriş
After removing the battery and motherboard, you must disassemble the bottom end of the tablet in order to gain access and disconnect the screen.
Neye ihtiyacın var
Use the screwdriver to remove the 4-3.5mm screws on the two lower speakers.
Bu adımda kullanılan alet:Tweezers$4.99
Use the fine pointed tweezers to carefully remove the 2 no-fuss speaker connections.
The last board we have to worry about is the board that holds the ribbon cable connector (from the battery removal step) and the screen connector.
Use the spudger to gently pry up on the bottom side of the board, as you did when removing the touch screen control board.
You have to make sure to loosen up the glue underneath and the board should come free from the frame.
Bir Yorum
How many pins does the screen have? because im planning to replace mine with a new one
