Ana içeriğe geç
Toshiba Encore WT8-A Tablet Camera Replacement
Neye ihtiyacın var
  1. Toshiba Encore WT8-A Tablet  Camera Replacement, Motherboard: adım 1, 1 resimden 1.
    • Remove the 4 – 4.5 mm screws from the motherboard assembly.
  2. Toshiba Encore WT8-A Tablet  Camera Replacement: adım 2, 1 resimden 1.
    • Remove the 2 – 3.5 mm screws from the motherboard assembly.
  3. Toshiba Encore WT8-A Tablet  Camera Replacement: adım 3, 1 resimden 1.
    • The motherboard should come free at this point.
  4. Toshiba Encore WT8-A Tablet  Camera Replacement, Camera: adım 4, 1 resimden 1.
    • Use small plastic opening tool for the following steps.
  5. Toshiba Encore WT8-A Tablet  Camera Replacement: adım 5, 2 resimden 1. Toshiba Encore WT8-A Tablet  Camera Replacement: adım 5, 2 resimden 2.
    • Use small plastic opening tool to pry rear facing camera flat top connector from motherboard.
  6. Toshiba Encore WT8-A Tablet  Camera Replacement: adım 6, 1 resimden 1.
    • The rear facing camera should come free at this point.
  7. Toshiba Encore WT8-A Tablet  Camera Replacement: adım 7, 1 resimden 1.
    • Use small plastic opening tool to pry front facing camera flat top connector from the motherboard
  8. Toshiba Encore WT8-A Tablet  Camera Replacement: adım 8, 2 resimden 1. Toshiba Encore WT8-A Tablet  Camera Replacement: adım 8, 2 resimden 2.
    • The front facing camera should come free at this point.
Sonuç
Melanie Mestre
116 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 17-4, Blackwell Fall 2016 USF Tampa, Team 17-4, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 693
