Ana içeriğe geç
Toshiba Encore WT8-A Tablet Motherboard Replacement
Neye ihtiyacın var
  1. Toshiba Encore WT8-A Tablet Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Use the metal spudger to create a gap between the back cover and the device.
    • Be gentle when using the metal spudger so that the casing is not damaged.
  2. Toshiba Encore WT8-A Tablet Motherboard Replacement: adım 2, 2 resimden 1. Toshiba Encore WT8-A Tablet Motherboard Replacement: adım 2, 2 resimden 2.
    • Use the nylon spudger to completely separate the back of the device.
    • Take the nylon spudger around the outside of the device cover until it comes free.
  3. Toshiba Encore WT8-A Tablet Motherboard Replacement: adım 3, 2 resimden 1. Toshiba Encore WT8-A Tablet Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the Phillips head PH0 to remove the 7 battery screws.
    • The 5 side screws measure 3.5mm.
    • The 2 top and bottom screws measure 4.5 mm.
  4. Toshiba Encore WT8-A Tablet Motherboard Replacement: adım 4, 2 resimden 1. Toshiba Encore WT8-A Tablet Motherboard Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • To disconnect the cable, use the fine tweezers to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • The zero insertion force (ZIF) connector is used to secure delicate ribbon cables, such as this trackpad cable.
  5. Toshiba Encore WT8-A Tablet Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the colored power cable from its connector.
    • To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    • Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Be sure to be very gentle when prying colored wires from motherboard to ensure that there is no damage.
  6. Toshiba Encore WT8-A Tablet Motherboard Replacement: adım 6, 1 resimden 1.
    • Battery will lift out of the device.
  7. Toshiba Encore WT8-A Tablet Motherboard Replacement, Motherboard: adım 7, 1 resimden 1.
    • Remove the 4 – 4.5 mm screws from the motherboard assembly.
  8. Toshiba Encore WT8-A Tablet Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the 2 – 3.5 mm screws from the motherboard assembly.
  9. Toshiba Encore WT8-A Tablet Motherboard Replacement: adım 9, 1 resimden 1.
    • The motherboard should come free at this point.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zachary Armstrong
293 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-4, Blackwell Fall 2016 USF Tampa, Team 17-4, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 2,072
