Ana içeriğe geç
Toshiba Equium M70 Faulty Graphics
Neye ihtiyacın var
  1. Toshiba Equium M70 Faulty Graphics, Toshiba Equium M70 Faulty Graphics: adım 1, 1 resimden 1.
    • This is a complete top half strip down to fix (takes me less than 30 minutes)
  2. Toshiba Equium M70 Faulty Graphics: adım 2, 1 resimden 1.
    • this is the culprit, as you can see the shim can easily overheat & go concave lifting off the chip.
  3. Toshiba Equium M70 Faulty Graphics: adım 3, 1 resimden 1.
    • cut a thin piece of alloy to the same size as the existing shim, i used an old alloy door push plate(easy to cut) & is the ideal thickness
  4. Toshiba Equium M70 Faulty Graphics: adım 4, 1 resimden 1.
    • Thoroughly clean the chip with pure alcohol, then apply an even spread of good quality thermal paste(Arctic silver 5) will never let you down
  5. Toshiba Equium M70 Faulty Graphics: adım 5, 1 resimden 1.
    • THen apply more thermal paste to the top of the shim
  6. Toshiba Equium M70 Faulty Graphics: adım 6, 1 resimden 1.
    • The new alloy shim is under the existing thin shim. I've done more than 20 of these repairs & had 100% success rate I always do the same to the CPU (might as well your already in there).,
  7. Toshiba Equium M70 Faulty Graphics: adım 7, 1 resimden 1.
    • This is the CPU with the new alloy shim fitted.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Terry Sim
207 İtibar
1 Kılavuz yazıldı
Bir Yorum
Pros: Very good hi-res pictures, well explained.
Cons: The disassembly instructions are missing
Nicola Nascimento - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 2,037
