Ana içeriğe geç
Toshiba Excite 10 AT300 Battery Replacement
Neye ihtiyacın var
  1. Toshiba Excite 10 AT300 Battery Replacement, Remove SD Card: adım 1, 1 resimden 1.
    • Remove the SD card from the SD card slot.
  2. Toshiba Excite 10 AT300 Battery Replacement, Open the Tablet: adım 2, 3 resimden 1. Toshiba Excite 10 AT300 Battery Replacement, Open the Tablet: adım 2, 3 resimden 2. Toshiba Excite 10 AT300 Battery Replacement, Open the Tablet: adım 2, 3 resimden 3.
    • Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
  3. Toshiba Excite 10 AT300 Battery Replacement, Disconnect Speaker Wires: adım 3, 3 resimden 1. Toshiba Excite 10 AT300 Battery Replacement, Disconnect Speaker Wires: adım 3, 3 resimden 2. Toshiba Excite 10 AT300 Battery Replacement, Disconnect Speaker Wires: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out.
    • Be careful not to rip the wires out of the white connector piece.
  4. Toshiba Excite 10 AT300 Battery Replacement, Remove Screws: adım 4, 2 resimden 1. Toshiba Excite 10 AT300 Battery Replacement, Remove Screws: adım 4, 2 resimden 2.
    • Using a #00 Phillips screwdriver, remove the following screws:
    • Five 3mm Phillips #00 screws
  5. Toshiba Excite 10 AT300 Battery Replacement, Remove Battery Cable: adım 5, 3 resimden 1. Toshiba Excite 10 AT300 Battery Replacement, Remove Battery Cable: adım 5, 3 resimden 2. Toshiba Excite 10 AT300 Battery Replacement, Remove Battery Cable: adım 5, 3 resimden 3.
    • Gently lift the battery, pulling away from the tab holding it in place at the bottom.
    • While holding the battery up, use a pair of tweezers to remove the battery cable from its connector.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Andrew Gillis
564 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-26, Maness Fall 2014 Cal Poly, Team 14-26, Maness Fall 2014 üyesi
CPSU-MANESS-F14S14G26
4 Üyeler
12 adet Kılavuz yazıldı
5 Yorum
My tablet won't come on what do i do? It was working yesterday with no problem when I plugged it in this morning to charge it while I was gone when I came back it would come on at all . It felt hot.
lajenaolson - Yanıt
Thank you kindly. It took 20 minutes total.
Jamie Kitchens - Yanıt
My tablet comes but it's want to go to main screen
Sylvia Chambers - Yanıt
How do I get another battery for my Toshiba tablet
Tracy - Yanıt
Ça m'a pris 20 min.La batterie est HS.Comment la brancher directement sur électricité ???!!?
Josephen Zacchari - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 18,889
