Ana içeriğe geç
Toshiba Excite 10 AT300 Front-Facing Camera Replacement
Neye ihtiyacın var
  1. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove SD Card: adım 1, 1 resimden 1.
    • Remove the SD card from the SD card slot.
  2. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Open the Tablet: adım 2, 3 resimden 1. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Open the Tablet: adım 2, 3 resimden 2. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Open the Tablet: adım 2, 3 resimden 3.
    • Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
  3. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Disconnect Speaker Wires: adım 3, 3 resimden 1. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Disconnect Speaker Wires: adım 3, 3 resimden 2. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Disconnect Speaker Wires: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out.
    • Be careful not to rip the wires out of the white connector piece.
  4. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove Screws: adım 4, 2 resimden 1. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove Screws: adım 4, 2 resimden 2.
    • Using a #00 Phillips screwdriver, remove the following screws:
    • Five 3mm Phillips #00 screws
  5. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove Battery Cable: adım 5, 3 resimden 1. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove Battery Cable: adım 5, 3 resimden 2. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove Battery Cable: adım 5, 3 resimden 3.
    Satın Al
    • Gently lift the battery, pulling away from the tab holding it in place at the bottom.
    • While holding the battery up, use a pair of tweezers to remove the battery cable from its connector.
  6. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove the foil wire: adım 6, 2 resimden 1. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove the foil wire: adım 6, 2 resimden 2.
    Satın Al
    • Using tweezers, pull the copper foil up from the back of the camera. It should peel up easily.
    • Warning: Be careful to avoid ripping the foil.
  7. Toshiba Excite 10 AT300 Front-Facing Camera Replacement, Remove the ribbon cable: adım 7, 1 resimden 1.
    • Carefully remove the ribbon cable from the housing by pulling gently upwards on the sides of the cable housing. The cable should come straight up off of its housing.
Sonuç
Gus Holz
297 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-26, Maness Fall 2014 Cal Poly, Team 14-26, Maness Fall 2014 üyesi
CPSU-MANESS-F14S14G26
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 688
