Ana içeriğe geç
Toshiba Excite 10 AT300 Rear-Facing Camera Replacement
Neye ihtiyacın var
  1. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove SD Card: adım 1, 1 resimden 1.
    • Remove the SD card from the SD card slot.
  2. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Open the Tablet: adım 2, 3 resimden 1. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Open the Tablet: adım 2, 3 resimden 2. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Open the Tablet: adım 2, 3 resimden 3.
    • Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
  3. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Disconnect Speaker Wires: adım 3, 3 resimden 1. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Disconnect Speaker Wires: adım 3, 3 resimden 2. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Disconnect Speaker Wires: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out.
    • Be careful not to rip the wires out of the white connector piece.
  4. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Screws: adım 4, 2 resimden 1. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Screws: adım 4, 2 resimden 2.
    • Using a #00 Phillips screwdriver, remove the following screws:
    • Five 3mm Phillips #00 screws
  5. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Battery Cable: adım 5, 3 resimden 1. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Battery Cable: adım 5, 3 resimden 2. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Battery Cable: adım 5, 3 resimden 3.
    Satın Al
    • Gently lift the battery, pulling away from the tab holding it in place at the bottom.
    • While holding the battery up, use a pair of tweezers to remove the battery cable from its connector.
  6. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove screw and yellow tape: adım 6, 1 resimden 1.
    Satın Al
    • Using a #00 Philips screwdriver, remove the screw attaching daughter board.
    • Remove the yellow tape using a pair of tweezers.
  7. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Ribbon Cable: adım 7, 3 resimden 1. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Ribbon Cable: adım 7, 3 resimden 2. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Ribbon Cable: adım 7, 3 resimden 3.
    • Unlock the ribbon cable housing using tweezers and/or a spudger.
    • Gently pull the ribbon cable out of its housing using the tweezers or your hands.
  8. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove copper foil wires: adım 8, 3 resimden 1. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove copper foil wires: adım 8, 3 resimden 2. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove copper foil wires: adım 8, 3 resimden 3.
    • Pull copper tape away from the back, keeping it connected to the green rear camera board.
    • Be careful not to rip the copper tape.
  9. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove the daughter board: adım 9, 2 resimden 1. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove the daughter board: adım 9, 2 resimden 2.
    • Using your hands remove daughter board by lifting it off of the tablet chassis. Flip it over and place it next to the tablet face-down.
    • Do not disconnect the red and black wires connecting it to the vibrating mechanism.
  10. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement: adım 10, 2 resimden 1. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement: adım 10, 2 resimden 2.
    • Gently pinch the ribbon cable connector between two fingers or with tweezers and pull it straight outwards. The ribbon cable connector should disconnect and the camera can now be replaced.
Sonuç
Gus Holz
297 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-26, Maness Fall 2014 Cal Poly, Team 14-26, Maness Fall 2014 üyesi
CPSU-MANESS-F14S14G26
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 531
