Ana içeriğe geç
Toshiba Excite 7 Screen Replacement
Neye ihtiyacın var
  1. Toshiba Excite 7 Screen Replacement, Battery Removal: adım 1, 3 resimden 1. Toshiba Excite 7 Screen Replacement, Battery Removal: adım 1, 3 resimden 2. Toshiba Excite 7 Screen Replacement, Battery Removal: adım 1, 3 resimden 3.
    • Remove the back cover.
    • Work your fingernail or flat object under the cover’s seal. Start at the top right corner just above the front facing camera this is the device “Weak Spot”.
    • After you pry open the first clip slide the flat object along the perimeter of the cover until the cover is removable. You should hear the clips pop open.
  2. Toshiba Excite 7 Screen Replacement, Remove Tape: adım 2, 2 resimden 1. Toshiba Excite 7 Screen Replacement, Remove Tape: adım 2, 2 resimden 2.
    • Remove any black tape from the device.
    • Keep the tape, you will need to put it back on when you are done.
  3. Toshiba Excite 7 Screen Replacement, Unplug Wires: adım 3, 2 resimden 1. Toshiba Excite 7 Screen Replacement, Unplug Wires: adım 3, 2 resimden 2.
    • Unplug the wires from the battery.
    • The battery is the black rectangle in the middle of the device. The device has two wiring harnesses attached to it, one just above the battery and one just to the right.
  4. Toshiba Excite 7 Screen Replacement, remove screws: adım 4, 2 resimden 1. Toshiba Excite 7 Screen Replacement, remove screws: adım 4, 2 resimden 2.
    • Unscrew the battery from the device.
    • The device has 5 screws to remove, keep the screws.
  5. Toshiba Excite 7 Screen Replacement, Unclip and remove battery: adım 5, 2 resimden 1. Toshiba Excite 7 Screen Replacement, Unclip and remove battery: adım 5, 2 resimden 2.
    • The battery has one clip you will need to remove. The clip is located at the bottom right corner of the battery just above the right speaker. The speakers and wires are not secured to the battery, they may fall off.
    • Push the clip back then lift the battery up.
  6. Toshiba Excite 7 Screen Replacement, Remove Data cable: adım 6, 1 resimden 1.
    • The screen is connected to the circuit board by 2 “Data Cables” (orange ribbons). Data cables include 3 working components, data cables, the white harness plug, and the black lever.
    • Gently flip the black lever up and unplug data cables.
  7. Toshiba Excite 7 Screen Replacement, Removing the Circuit Board: adım 7, 1 resimden 1.
    • Remove the circuit board by gently coaxing it from the clips located just to the right of the circuit board.
  8. Toshiba Excite 7 Screen Replacement, Installing the Replacement Screen Assembly: adım 8, 2 resimden 1. Toshiba Excite 7 Screen Replacement, Installing the Replacement Screen Assembly: adım 8, 2 resimden 2.
    • The screen has a rubber device used to support the volume control switch.
    • Remove the rubber device from the old screen.
    • Make sure you keep the rubber device to be install into the new screen.
    • Repeat other steps in reverse to install replacement screen.
Sonuç
Sean Ulch
340 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Tanski Winter 2015 USF Tampa, Team 1-3, Tanski Winter 2015 üyesi
USFT-TANSKI-W15S1G3
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 1,329
