Ana içeriğe geç
Toshiba Excite 7c Battery Replacement
Neye ihtiyacın var
  1. Toshiba Excite 7c Battery Replacement, Open  Device: adım 1, 2 resimden 1. Toshiba Excite 7c Battery Replacement, Open  Device: adım 1, 2 resimden 2.
    • To open your device use the plastic opener. Locate the seam on your device and gently separate applying pressure down all four sides.
    • The back casing will start to peel away from the screen.
    • Carefully lift and remove the back panel with tablet lying face down on table. this will reveal the back side.
  2. Toshiba Excite 7c Battery Replacement, Remove Battery: adım 2, 3 resimden 1. Toshiba Excite 7c Battery Replacement, Remove Battery: adım 2, 3 resimden 2. Toshiba Excite 7c Battery Replacement, Remove Battery: adım 2, 3 resimden 3.
    • Locate the battery on the back of your device.
    • Remove the battery connector using a pair of tweezers.
    • On the side of the battery peel back but do not remove the two black pieces of tape.
    • Remove just to the white line NOT completely.
    • Carefully lift the battery out of the device, and set aside.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Reyna Serrato
96 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-2, Johnson Fall 2014 Gateway, Team 1-2, Johnson Fall 2014 üyesi
GCC-JOHNSON-F14S1G2
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 666
