Giriş
This guide will show you how to replace the camera on your Toshiba Excite 7c. The camera itself plugs directly into the motherboard and can be slightly more difficult to replace than other componants.
Neye ihtiyacın var
Place an iFixit opening tool in the seam between the screen and back casing.
Apply pressure down all four sides to separate the back casing from the screen.
Place the tablet face down and carefully remove the back panel.
Bu adımda kullanılan alet:Tweezers$4.99
Locate the camera on the top portion of the motherboard as seen here.
Grip using the tweezers and pull directly up applying as much force as necessary to remove the camera.
Bir başkası bu kılavuzu tamamladı.
