Giriş
This guide will show you how to replace the motherboard on your Toshiba Excite 7c. The logic board should only be replaced as a last ditch effort, as it is usually something else wrong first, unless there is visible damage.
Parçalar
Hiçbir parça belirtilmedi.
To open your device use the plastic opener. Locate the seam on your device and gently separate, applying pressure down all four sides.
The back casing will start to peel away from the screen.
Carefully lift and remove the back panel with tablet lying face down on a table. This will reveal the back side.
Bir başkası bu kılavuzu tamamladı.
