Ana içeriğe geç
Toshiba Excite 7c Screen Replacement
Neye ihtiyacın var
  1. Toshiba Excite 7c Screen Replacement, Motherboard: adım 1, 2 resimden 1. Toshiba Excite 7c Screen Replacement, Motherboard: adım 1, 2 resimden 2.
    • Place an iFixit opening tool in the seam between the screen and back casing.
    • Apply pressure down all four sides to separate the back casing from the screen.
    • Place the tablet face down and carefully remove the back panel.
  2. Toshiba Excite 7c Screen Replacement: adım 2, 2 resimden 1. Toshiba Excite 7c Screen Replacement: adım 2, 2 resimden 2.
    • Use a Phillips screwdriver to remove the five 6 mm screws from the motherboard.
    • Use tweezers to gently disconnect the two ribbon cables.
    • Pull straight up to remove the board.
  3. Toshiba Excite 7c Screen Replacement, Screen: adım 3, 1 resimden 1.
    • With all of the components removed continue with reassembly using a new screen as the base for reassembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Reyna Serrato
96 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-2, Johnson Fall 2014 Gateway, Team 1-2, Johnson Fall 2014 üyesi
GCC-JOHNSON-F14S1G2
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 345
