Ana içeriğe geç
Toshiba HD-A2 Drive Belt Replacement
Neye ihtiyacın var
  1. Toshiba HD-A2 Drive Belt Replacement, Top Panel: adım 1, 1 resimden 1.
    • Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
  2. Toshiba HD-A2 Drive Belt Replacement: adım 2, 2 resimden 1. Toshiba HD-A2 Drive Belt Replacement: adım 2, 2 resimden 2.
    • Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
  3. Toshiba HD-A2 Drive Belt Replacement: adım 3, 1 resimden 1.
    • Using your hand, gently lift the black top panel and safely place it off to the side.
  4. Toshiba HD-A2 Drive Belt Replacement, Optical Drive: adım 4, 3 resimden 1. Toshiba HD-A2 Drive Belt Replacement, Optical Drive: adım 4, 3 resimden 2. Toshiba HD-A2 Drive Belt Replacement, Optical Drive: adım 4, 3 resimden 3.
    • Remove five 6mm Phillips screws with a Phillips #2 screwdriver.
    • The 2 screws on the right of the cartridge are better shown in the second and third photos.
  5. Toshiba HD-A2 Drive Belt Replacement: adım 5, 2 resimden 1. Toshiba HD-A2 Drive Belt Replacement: adım 5, 2 resimden 2.
    • Remove the remaining four 6mm Phillips screws.
  6. Toshiba HD-A2 Drive Belt Replacement: adım 6, 3 resimden 1. Toshiba HD-A2 Drive Belt Replacement: adım 6, 3 resimden 2. Toshiba HD-A2 Drive Belt Replacement: adım 6, 3 resimden 3.
    • Using your fingers, gently remove the metal pieces on each side of the cartridge and carefully place them aside.
  7. Toshiba HD-A2 Drive Belt Replacement: adım 7, 2 resimden 1. Toshiba HD-A2 Drive Belt Replacement: adım 7, 2 resimden 2.
    • Gently lift the cartridge. Remove two 4mm Phillips screws from the green circuit board.
  8. Toshiba HD-A2 Drive Belt Replacement: adım 8, 1 resimden 1.
    • Using your fingers, gently pull off the wires.
  9. Toshiba HD-A2 Drive Belt Replacement: adım 9, 2 resimden 1. Toshiba HD-A2 Drive Belt Replacement: adım 9, 2 resimden 2.
    • Using your fingers, pull off the green circuit board from the cartridge and carefully place it down.
    • Be careful not to rip the tape attaching the green circuit boards together.
  10. Toshiba HD-A2 Drive Belt Replacement: adım 10, 2 resimden 1. Toshiba HD-A2 Drive Belt Replacement: adım 10, 2 resimden 2.
    • Flip the cartridge over to the bare side with no stickers. Remove four 10mm Phillips screws from each corner.
  11. Toshiba HD-A2 Drive Belt Replacement: adım 11, 2 resimden 1. Toshiba HD-A2 Drive Belt Replacement: adım 11, 2 resimden 2.
    • Using your hands, gently lift the lid and carefully place it aside.
  12. Toshiba HD-A2 Drive Belt Replacement: adım 12, 3 resimden 1. Toshiba HD-A2 Drive Belt Replacement: adım 12, 3 resimden 2. Toshiba HD-A2 Drive Belt Replacement: adım 12, 3 resimden 3.
    • Flip over the cartridge. Using your hands, gently lift the rest of the silver case.
  13. Toshiba HD-A2 Drive Belt Replacement, Drive Belt: adım 13, 3 resimden 1. Toshiba HD-A2 Drive Belt Replacement, Drive Belt: adım 13, 3 resimden 2. Toshiba HD-A2 Drive Belt Replacement, Drive Belt: adım 13, 3 resimden 3.
    • Slide out the disc tray. If it's stuck, turn the white gear to the right to release the tray.
  14. Toshiba HD-A2 Drive Belt Replacement: adım 14, 1 resimden 1.
    • The drive belt is the black rubber band.
  15. Toshiba HD-A2 Drive Belt Replacement: adım 15, 2 resimden 1. Toshiba HD-A2 Drive Belt Replacement: adım 15, 2 resimden 2.
    • Using your fingers, gently remove the drive belt.
    • If you have difficulty using your fingers, use a prying tool.
Sonuç
Nouriyah Saleh
800 İtibar
6 adet Kılavuz yazıldı
Ekip
UC Davis, Team S11-G1, Lore Fall 2018 UC Davis, Team S11-G1, Lore Fall 2018 üyesi
UCD-LORE-F18S11G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 392
