Ana içeriğe geç
Toshiba HD-A2 Power Button Replacement
Neye ihtiyacın var
  1. Toshiba HD-A2 Power Button Replacement, Power Button: adım 1, 3 resimden 1. Toshiba HD-A2 Power Button Replacement, Power Button: adım 1, 3 resimden 2. Toshiba HD-A2 Power Button Replacement, Power Button: adım 1, 3 resimden 3.
    • Using your hands, pop off the black console from each hinge surrounding the case.
    • There are a total of 7 hinges.
  2. Toshiba HD-A2 Power Button Replacement: adım 2, 1 resimden 1.
    • With the inside of the console facing up, the power button will be encased in clear plastic located on the right side of the console.
  3. Toshiba HD-A2 Power Button Replacement: adım 3, 2 resimden 1. Toshiba HD-A2 Power Button Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the single screw holding the power button to the console.
    • After taking out the screw, the small piece of metal underneath will come loose. Carefully place this part aside.
  4. Toshiba HD-A2 Power Button Replacement: adım 4, 1 resimden 1.
    • Using your fingers, gently pull out the power button. You can push it from the outside to help loosen it from its hinges.
Sonuç
Nouriyah Saleh
800 İtibar
6 adet Kılavuz yazıldı
Ekip
UC Davis, Team S11-G1, Lore Fall 2018 UC Davis, Team S11-G1, Lore Fall 2018 üyesi
UCD-LORE-F18S11G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 171
