Ana içeriğe geç
Toshiba Mini NB505 WiFi Card Replacement
Neye ihtiyacın var
  1. Toshiba Mini NB505 WiFi Card Replacement, Bottom Plate: adım 1, 1 resimden 1.
    • Locate the two 1.2mm philips #000 screws holding the bottom plate onto the laptop.
  2. Toshiba Mini NB505 WiFi Card Replacement: adım 2, 1 resimden 1.
    • Using a Philips head #000 screwdriver, carefully remove the two 1.2mm screws.
  3. Toshiba Mini NB505 WiFi Card Replacement: adım 3, 1 resimden 1.
    • The plate can now be easily removed.
  4. Toshiba Mini NB505 WiFi Card Replacement, WiFi Card: adım 4, 1 resimden 1.
    • Locate the WiFi card by following the black and white wiring inside of the laptop.
  5. Toshiba Mini NB505 WiFi Card Replacement: adım 5, 2 resimden 1. Toshiba Mini NB505 WiFi Card Replacement: adım 5, 2 resimden 2.
    • Locate and gently pull up on the black and white wires connecting to the card.
  6. Toshiba Mini NB505 WiFi Card Replacement: adım 6, 1 resimden 1.
    • Locate the two 1.2 mm phillips #000 screws holding the WiFi card.
  7. Toshiba Mini NB505 WiFi Card Replacement: adım 7, 1 resimden 1.
    • Use a Phillips head #000 screwdriver to remove the two 1.2mm screws holding the card into the laptop.
  8. Toshiba Mini NB505 WiFi Card Replacement: adım 8, 1 resimden 1.
    • Once the card pops up, gentle remove it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Owen Velho
508 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-7, Catania Spring 2016 UMass Dartmouth, Team 7-7, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G7
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 900
