Ana içeriğe geç
Toshiba NB205 N330PK Key Cleaning
Neye ihtiyacın var
  1. Toshiba NB205 N330PK Key Cleaning, Toshiba NB205 N330PK Key Cleaning: adım 1, 1 resimden 1.
    • Using the spudger, gently pry the desired key up on one side. This will release the key.
    • The key is held in place by very small plastic pieces. Improper removal or installation may damage key permanently and require entire keyboard replacement.
  2. Toshiba NB205 N330PK Key Cleaning: adım 2, 2 resimden 1. Toshiba NB205 N330PK Key Cleaning: adım 2, 2 resimden 2.
    • Use a brush to remove debris and use a cleaner cloth to remove residue.
    • Similarly, remove debris and residue from the area of the keyboard where the key was originally seated.
  3. Toshiba NB205 N330PK Key Cleaning: adım 3, 1 resimden 1.
    • Once clean, set the key above its original position and firmly press it back into place.
    • If cleaned and installed properly the key should depress smoothly and spring back to normal position once released.
Sonuç
This is a complete guide to removing a key and cleaning the area before replacement.
Mason McCaskill
1.000 İtibar
9 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G2
3 Üyeler
27 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 479
