Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using the spudger, gently pry the desired key up on one side. This will release the key.
Use a brush to remove debris and use a cleaner cloth to remove residue.
Similarly, remove debris and residue from the area of the keyboard where the key was originally seated.
Once clean, set the key above its original position and firmly press it back into place.
If cleaned and installed properly the key should depress smoothly and spring back to normal position once released.
