Ana içeriğe geç
Toshiba NB205 N330PK RAM Replacement
Neye ihtiyacın var
  1. Toshiba NB205 N330PK RAM Replacement, RAM: adım 1, 2 resimden 1. Toshiba NB205 N330PK RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Use a bit driver and a Phillips #0 bit to remove the one 5 mm retaining screw.
    • Lift the panel up and out of the way.
  2. Toshiba NB205 N330PK RAM Replacement: adım 2, 3 resimden 1. Toshiba NB205 N330PK RAM Replacement: adım 2, 3 resimden 2. Toshiba NB205 N330PK RAM Replacement: adım 2, 3 resimden 3.
    • The RAM chip is secured by two retaining arms that run parallel with the chip. Gently pull these arms in opposite directions off of the chip.
    • After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal.
  3. Toshiba NB205 N330PK RAM Replacement: adım 3, 2 resimden 1. Toshiba NB205 N330PK RAM Replacement: adım 3, 2 resimden 2.
    • Push the replacement RAM into the original position.
    • Reattach both securing arms onto the sides of the RAM chip.
  4. Toshiba NB205 N330PK RAM Replacement: adım 4, 2 resimden 1. Toshiba NB205 N330PK RAM Replacement: adım 4, 2 resimden 2.
    • Place the panel back into the securing slots and let it rest in its original position.
    • With the bit driver and Phillips #0 bit, secure the panel down with one screw.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mason McCaskill
1.021 İtibar
9 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G2
3 Üyeler
27 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 524
