Ana içeriğe geç
Toshiba NB305 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba NB305 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Hard Drive Replacement: adım 3, 2 resimden 1. Toshiba NB305 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 1. Toshiba NB305 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 2. Toshiba NB305 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Locate the two torx T-6 screws on the back of the laptop and remove them.
    • 6mm Torx T-6 screws.
    • 3mm Torx T-6 screws.
  5. Toshiba NB305 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Note that the screw on the left is longer than the screw on the right.
  6. Toshiba NB305 Hard Drive Replacement: adım 6, 2 resimden 1. Toshiba NB305 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Using spudger, pry the panel up.
  7. Toshiba NB305 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Remove hard drive by pulling to the right and then upward and out.
Sonuç
Nuri Chung
368 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-5, Lacy Fall 2016 USF Tampa, Team 5-5, Lacy Fall 2016 üyesi
USFT-LACY-F16S5G5
3 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 1,490
