Ana içeriğe geç
Toshiba NB305 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba NB305 Keyboard  Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Keyboard  Replacement: adım 2, 1 resimden 1.
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Keyboard  Replacement: adım 3, 2 resimden 1. Toshiba NB305 Keyboard  Replacement: adım 3, 2 resimden 2.
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Keyboard  Replacement, Keyboard: adım 4, 2 resimden 1. Toshiba NB305 Keyboard  Replacement, Keyboard: adım 4, 2 resimden 2.
    • Remove the four F4 screws and the F6 screw underneath battery.
    • 4mm Phillips-0 screws.
    • 6mm Phillips-0 screws.
  5. Toshiba NB305 Keyboard  Replacement: adım 5, 3 resimden 1. Toshiba NB305 Keyboard  Replacement: adım 5, 3 resimden 2. Toshiba NB305 Keyboard  Replacement: adım 5, 3 resimden 3.
    • Using a spudger, gently pry out on the plastic cover.
    • Turn it over and remove plastic cover on top of laptop with power button on it.
  6. Toshiba NB305 Keyboard  Replacement: adım 6, 2 resimden 1. Toshiba NB305 Keyboard  Replacement: adım 6, 2 resimden 2.
    • Use the plastic opening tool in little notches above the keyboard
    • Gently pry up on the keyboard until it lifts up.
    • You might hear a click when the keyboard releases.
  7. Toshiba NB305 Keyboard  Replacement: adım 7, 1 resimden 1.
    • Gently lift the keyboard up toward the screen.
    • Be careful! There is a cable still connected from the computer to the keyboard.
  8. Toshiba NB305 Keyboard  Replacement: adım 8, 2 resimden 1. Toshiba NB305 Keyboard  Replacement: adım 8, 2 resimden 2.
    • The ribbon cable has a clip on each side holding it to the motherboard.
    • Using a spudger, press on the clips to release the cable.
    • The cable will slide out on its own when it is properly released.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nuri Chung
368 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-5, Lacy Fall 2016 USF Tampa, Team 5-5, Lacy Fall 2016 üyesi
USFT-LACY-F16S5G5
3 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 690
