Ana içeriğe geç
Toshiba NB305 RAM Replacement
Neye ihtiyacın var
  1. Toshiba NB305 RAM  Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop upside down with the battery facing you.
    FixBot'a Sor
  2. Toshiba NB305 RAM  Replacement: adım 2, 1 resimden 1.
    • Use your right hand to move latch 1 to the right to unlock the battery.
    FixBot'a Sor
  3. Toshiba NB305 RAM  Replacement: adım 3, 2 resimden 1. Toshiba NB305 RAM  Replacement: adım 3, 2 resimden 2.
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
    FixBot'a Sor
  4. Toshiba NB305 RAM  Replacement, RAM: adım 4, 1 resimden 1.
    • The RAM is located underneath the top left panel on the back of the laptop.
    • Remove the captive Phillips-0 screw with a screwdriver.
    FixBot'a Sor
  5. Toshiba NB305 RAM  Replacement: adım 5, 2 resimden 1. Toshiba NB305 RAM  Replacement: adım 5, 2 resimden 2.
    • Using a spudger pry up on the open slit next to the screw.
    FixBot'a Sor
  6. Toshiba NB305 RAM  Replacement: adım 6, 2 resimden 1. Toshiba NB305 RAM  Replacement: adım 6, 2 resimden 2.
    • The RAM is held in place with two clips, one on each side.
    • Using two plastic opening tools (or your fingers) pull two tabs holding RAM outwards.
    • The RAM card will pop up when it is released.
    FixBot'a Sor
  7. Toshiba NB305 RAM  Replacement: adım 7, 2 resimden 1. Toshiba NB305 RAM  Replacement: adım 7, 2 resimden 2.
    • Pull the RAM straight out of the slot.
    FixBot'a Sor
Sonuç
Nuri Chung
377 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-5, Lacy Fall 2016 USF Tampa, Team 5-5, Lacy Fall 2016 üyesi
USFT-LACY-F16S5G5
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 980
