Ana içeriğe geç
Toshiba NB305 Wifi Card Replacement
Neye ihtiyacın var
  1. Toshiba NB305 Wifi Card Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Wifi Card Replacement: adım 2, 1 resimden 1.
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Wifi Card Replacement: adım 3, 2 resimden 1. Toshiba NB305 Wifi Card Replacement: adım 3, 2 resimden 2.
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Wifi Card Replacement, Wifi Card: adım 4, 3 resimden 1. Toshiba NB305 Wifi Card Replacement, Wifi Card: adım 4, 3 resimden 2. Toshiba NB305 Wifi Card Replacement, Wifi Card: adım 4, 3 resimden 3.
    • Locate the two torx T-6 screws on the back of the laptop and remove them.
    • 6mm Torx T-6 Screws
  5. Toshiba NB305 Wifi Card Replacement: adım 5, 2 resimden 1. Toshiba NB305 Wifi Card Replacement: adım 5, 2 resimden 2.
    • Using a spudger pry the panel up.
  6. Toshiba NB305 Wifi Card Replacement: adım 6, 2 resimden 1. Toshiba NB305 Wifi Card Replacement: adım 6, 2 resimden 2.
    • Using a spudger pry up and off the two wire connections.
    • Note that the black wire is on the top of the card and the white is the bottom.
  7. Toshiba NB305 Wifi Card Replacement: adım 7, 2 resimden 1. Toshiba NB305 Wifi Card Replacement: adım 7, 2 resimden 2.
    • Remove the two Phillips 0 size screws on WIFI card.
    • Once the screws are removed the WIFI card will raise up
  8. Toshiba NB305 Wifi Card Replacement: adım 8, 2 resimden 1. Toshiba NB305 Wifi Card Replacement: adım 8, 2 resimden 2.
    • Grip both sides of the wifi card with your hand.
    • Lift up on the card and pull the card out of the slot
Sonuç
Mateo Fontana
286 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-5, Lacy Fall 2016 USF Tampa, Team 5-5, Lacy Fall 2016 üyesi
USFT-LACY-F16S5G5
3 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 429
