Ana içeriğe geç
Toshiba Portege 3110CT Laptop Screen Replacement
Neye ihtiyacın var
  1. Toshiba Portege 3110CT Laptop Screen Replacement, Laptop Screen: adım 1, 1 resimden 1.
    • Begin by removing the battery and flipping the laptop over to see the screws
    • Using a phillips head screwdriver to remove the screws that secure the back
  2. Toshiba Portege 3110CT Laptop Screen Replacement: adım 2, 1 resimden 1.
    • Flip the laptop back over and open it up carefully
    • Lift up the bottom panel where the mouse click buttons are
    • Lift up slowly as simply flip it up and rest it on the keyboard as not to damage the ribbon cable connecting it
    • Using the spudger disconnect the ribbon cable connected to the bottom of the panel
  3. Toshiba Portege 3110CT Laptop Screen Replacement: adım 3, 1 resimden 1.
    • Using the same size phillips as before remove the two screws that hold the keyboard in place
    • Then simply lift the keyboard up and slide it down and out
  4. Toshiba Portege 3110CT Laptop Screen Replacement: adım 4, 1 resimden 1.
    • Using the phillips remove the 3 screws that hold the screen mount to the rest of the keyboard
    • Once you remove the final screw be careful as the screen will want to fall back to prevent damage
  5. Toshiba Portege 3110CT Laptop Screen Replacement: adım 5, 1 resimden 1.
    • Pull the screen off the rest of the laptop and flip it over
    • Using the phillips screw driver remove the final 3 screws securing the screen
Sonuç
Ashley Furtado
101 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-4, Martin Fall 2016 UMass Dartmouth, Team 6-4, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S6G4
3 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 420
