Ana içeriğe geç
Toshiba Portege M300 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Portege M300 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 Hard Drive Replacement: adım 2, 2 resimden 1. Toshiba Portege M300 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 Hard Drive Replacement: adım 3, 2 resimden 1. Toshiba Portege M300 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 1. Toshiba Portege M300 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 2. Toshiba Portege M300 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Turn the computer over onto the back.
    • Use a Phillips #1 screwdriver to remove the screw from the hard drive cover.
    • Lift and remove the cover.
  5. Toshiba Portege M300 Hard Drive Replacement: adım 5, 3 resimden 1. Toshiba Portege M300 Hard Drive Replacement: adım 5, 3 resimden 2. Toshiba Portege M300 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Carefully remove the hard drive from the IDE cable by pulling on the black connector.
    • Do not pull the orange cable.
  6. Toshiba Portege M300 Hard Drive Replacement: adım 6, 2 resimden 1. Toshiba Portege M300 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Remove the two gray rubber covers from both ends of the hard drive.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Alison Wendt
135 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-51, Johann Spring 2013 Cal Poly, Team 21-51, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G51
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 22
Her zaman: 2,393
