Ana içeriğe geç
Toshiba Portege M300 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Portege M300 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 Keyboard Replacement: adım 2, 2 resimden 1. Toshiba Portege M300 Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 Keyboard Replacement: adım 3, 2 resimden 1. Toshiba Portege M300 Keyboard Replacement: adım 3, 2 resimden 2.
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 Keyboard Replacement, Keyboard: adım 4, 2 resimden 1. Toshiba Portege M300 Keyboard Replacement, Keyboard: adım 4, 2 resimden 2.
    • Use a plastic opening tool to unsnap the right hand side speaker cover.
  5. Toshiba Portege M300 Keyboard Replacement: adım 5, 2 resimden 1. Toshiba Portege M300 Keyboard Replacement: adım 5, 2 resimden 2.
    • Remove the rest of the cover by sliding it to the right and lifting the edge.
  6. Toshiba Portege M300 Keyboard Replacement: adım 6, 2 resimden 1. Toshiba Portege M300 Keyboard Replacement: adım 6, 2 resimden 2.
    • Use a Phillips head #00 screwdriver to remove the two silver screws at the top of the keyboard.
    • Two 4.0 mm coarse thread screws.
  7. Toshiba Portege M300 Keyboard Replacement: adım 7, 3 resimden 1. Toshiba Portege M300 Keyboard Replacement: adım 7, 3 resimden 2. Toshiba Portege M300 Keyboard Replacement: adım 7, 3 resimden 3.
    • Remove the Torx screw holding the left keyboard tab in place, and lift it to release.
    • One Torx T6 fine thread screw.
  8. Toshiba Portege M300 Keyboard Replacement: adım 8, 2 resimden 1. Toshiba Portege M300 Keyboard Replacement: adım 8, 2 resimden 2.
    • Turn the computer over on to the back.
    • Remove the middle screw with a Phillips head #000 screwdriver.
    • One 7.5 mm fine thread screw.
  9. Toshiba Portege M300 Keyboard Replacement: adım 9, 2 resimden 1. Toshiba Portege M300 Keyboard Replacement: adım 9, 2 resimden 2.
    • Turn the computer over to the front.
    • Gently pull at the top and bottom to remove the keyboard.
    • Peel off the black tape that holds the connection wire.
  10. Toshiba Portege M300 Keyboard Replacement: adım 10, 2 resimden 1. Toshiba Portege M300 Keyboard Replacement: adım 10, 2 resimden 2.
    • Flip the keyboard over and carefully unplug the connection wire.
    • Reverse the steps for proper instillation of the new keyboard.
Sonuç
Alison Wendt
135 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-51, Johann Spring 2013 Cal Poly, Team 21-51, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G51
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 14
Her zaman: 1,238
